Edit comments is not enabled in the review pan or tools menue
Post your questions, bug reports and suggestions here for FreeOffice TextMaker 2018 for Linux.
sanitair
Post by sanitair » Wed May 30, 2018 3:43 pm
I just installed FreeOffice on my Ubuntu 14.04 machine.
I tried to create a new text file and add review comments to it but the edit buttons are disabled.
selection of text while the comments pane should be enabled
I tried to open an existing file and add comments to it but I also failed due to the same reason
The comments pane should be enabled but it is not appearing as shown in the image
From the options, the document properties / reviewing should be enabled as below picture
The reviewing pan of the document properties
When I try to do it from the tools menu I have the same issue.
In the documentation it seems it is a pretty simple operation but it seems I am missing something.
tmlog.txt.zip
The log file of the debug mode
(28.58 KiB) Downloaded 41 times
I really appreciate your support
Re: Edit comments is not enabled in the review pan or tools menue
Post by sven-l » Thu Jun 07, 2018 3:14 pm
With the current version of FreeOffice 2018 you cannot create comments but (if there are already existing comments in a documents) you can edit them.
sanitair
Post by sanitair » Sat Jul 14, 2018 8:42 pm
Thank you for the update.
I am not sure why I can not add a comment while I can edit one !!
When this critical feature will be available? at which version?
Post by martin-k » Sun Jul 15, 2018 9:13 am
Return to “FreeOffice TextMaker 2018 for Linux”
