Install Error when trying to install under Kali Linux 32-bit (Debian)
General questions and answers about FreeOffice 2018 for Linux. Don't post application-specific questions here, but in the appropriate subforum.
cweir73
Post by cweir73 » Tue Dec 24, 2019 3:58 pm
I am getting the following error message when trying to install.
I have tried downloading the package again and also done a restart.
Error message:
root@kali:~# su
root@kali:~# apt-get update
Hit1:1 http://ftp.hands.com/kali kali-rolling InRelease
Reading package lists … Done
root@kali:~# dpkg -i softmaker-freeoffice-2018_973-01_i386.deb
(Reading database … 276611 files and directories currently installed.)
Preparing to unpack softmaker-freeoffice-2018_973-01_i386.deb …
Unpacking softmaker-freeoffice-2018 (2019) over (2919) ...
dpkg: dependency problems prevent configuration of softmaker-freeoffice-2018
softmaker-freeoffice-2018 depends on libgl1-mesa-glx; however:
Package libgl1-mesa-glx is not installed.
dpkg: error processing package softmaker-freeoffice-2018 (--install):
dependency problems - leaving unconfigured
Processing triggers for shared-mime-info (1.10-1) ...
Processing triggers for desktop-file-utils (0.24-1) …
Processing triggers for mime-support (3.64) …
Errors were encountered while processing:
root@kali:~#
I would be very grateful for any assistance in resolving this issue.
Re: Install Error when trying to install under Kali Linux 32-bit (Debian)
Post by miguel-c » Sat Dec 28, 2019 8:32 pm
Please go to https://www.freeoffice.com/en/tips-and-tricks-linux
If the standard Debian way of installing doesn't work, you may try the generic way at the bottom of the page:
"If your system is not listed here and you cannot run the installation with the instructions given above, you can install SoftMaker FreeOffice using our .tgz-based installation packages.
Depending on your system, download the 32-bit or 64-bit .tgz installation package. Then uncompress and untar it, and finally run the installation script inside:
If you use a 32-bit Linux system:
tar xvzf softmaker-freeoffice-2018-973-i386.tgz
./installfreeoffice
If you use a 64-bit Linux system:
tar xvzf softmaker-freeoffice-2018-973-amd64.tgz
./installfreeoffice
Return to “FreeOffice 2018 for Linux (General)”
