Softmaker does not notify when two users open the same file?
General questions and answers about FreeOffice 2018 for Linux. Don't post application-specific questions here, but in the appropriate subforum.
benin
Post by benin » Thu Jul 05, 2018 8:54 am
Hello I've installed softmaker on a windows machine and on a linux machine. When two users try to access the same file. either of the users weren't notified that the file is being used by the another user?
Re: Softmaker does not notify when two users open the same file?
Post by sven-l » Thu Jul 05, 2018 9:29 am
Yes, the same file can only be accessed with write access by one user at a time. All other users will only have a read access.
benin
Post by benin » Fri Jul 06, 2018 9:44 am
What I am saying is that the user should be notified that the file is accessed by another user ? but here it doesn't do that the file can be accessed by two users and both can write at the same time. ?
benin
Post by benin » Fri Jul 06, 2018 9:47 am
Freeoffice is not creating a lock file as in MS Office or LibreOffice ?
The file is editable for both users and none are notified that the other user is working on that file. Its not giving read-only notification instead two users have write permission..
Please apologize if my English is bad. I'd try my best convey my message to the best.
Post by martin-k » Fri Jul 06, 2018 10:00 am
Whenever we open a file in SoftMaker Office, we keep it open as long as you are editing it, so that other users will receive a warning and can open it only for reading.
Now, why that mechanism isn't working for you needs to be determined. First of all, the location where the file is stored: is it a network share? Which protocol are you using to access it? Samba? NFS? Something else? Second, which document file type did you use?
Also, I am moving this to the FreeOffice forum, since this is about FreeOffice.
benin
Post by benin » Fri Jul 06, 2018 10:12 am
The Files are on network file server under samba share
Server OS
Redhat 6
Samba version 3.5.10-114.el6
Client OS
Linux Mint 18.1 32bit
Ubuntu 14.04.5LTS 64bit
Windows 7 Ultimate 64bit.
Document Type
Text Maker
Plan Maker
File Extensions :
*.xls
*.xlsx
*.doc
*.docx
Post by martin-k » Fri Jul 06, 2018 10:13 am
Have you mounted the network share to a local folder, or are you directly accessing it with smbfs:// ?
benin
Post by benin » Fri Jul 06, 2018 10:26 am
On the windows machine I mapped it as a drive
On ubuntu I've opened via smb://serveripaddress/
benin
Post by benin » Sat Jul 07, 2018 11:53 am
It would be really great if you guys could look into this whether its my fault or a bug ? Hope to see a response from you soon
Post by sven-l » Tue Jul 10, 2018 1:40 pm
I can reproduce that issue here and will report it to the developers.
benin
Post by benin » Wed Jul 11, 2018 8:02 am
Thank You very much ..
Post by sven-l » Thu Jul 19, 2018 11:02 am
If you access a Samba share via the "smb//..." command in your file browser and then open a file with one of our applications from inside the file browser, a local copy of the file will be opened. Because of this, you don't get any warning that the file is write-protected – it's not that very file that gets opened, but a local copy. However, this shouldn't happen if you mount the samba share via "mount -t cifs...".
Return to “FreeOffice 2018 for Linux (General)”
