I have a problem , i can't input accents/tones in greek letters !
On libreoffice writer i have no problems but freeoffice won't input tones/accents on letters !
To input the accent i press the ΄ key and the the letter i want to have accent.
Look this example Ώ with accent -------- Ω without accent
Can you help me ?
I tried to use ibus and then freeoffice would even change language from english to greek i couldn't type in greek with ibus !
Re: I have a problem , i can't input accents/tones in greek letters !
Does that happen with all fonts?
Don't know if it's related, but my compose key (Caplocks), with which I enter symbols, no longer works after the last update?
The compose key still works in every other application.
In which Linux distribution does that happen?
Kubuntu 18.04. Can provide more info if needed but I'm on my Cinnamon system right now.Worth noting is that Tommy's 16.04 KDE NEON is also having trouble with this.
viewtopic.php?f=305&t=17751#p59415
Could be KDE/QT related?
I will report this issue to the developers.
