Can not Launch Presentation
neurita
Post by neurita » Mon Aug 24, 2020 3:36 am
I downloaded free office and I can not open the Presentation and it gave me this error message: LoadLibrary failed with error 1114: A dynamic link library (DLL) initialization routine failed. I uninstalled free office and reinstalled. I got the same error message when i opened the Presentations.
Will very much appreciate your help.
Thank you. Stay safe.
Re: Can not Launch Presentation
Post by SuperTech » Thu Aug 27, 2020 12:46 am
This is an Operating system-level corruption in your DLL file. Please repair your windows. You can find help related to this on Google, please check the following link: https://bit.ly/32uhLOb
Dmitry.petrikin
Post by Dmitry.petrikin » Wed Sep 02, 2020 4:30 pm
Добрый день. У меня похожая ситуация, также запускаются текстовый редактор и редактор таблиц, но презентации не открываются. Переустановил, проблема повторилась. Только код ошибки другой (во вложении к посту).
Post by SuperTech » Sat Sep 05, 2020 10:04 am
As I explained above this is an Operating system-level problem so please repair your Windows operating system for troubleshooting of this problem. I also shared the link.
This is an English only forum so please use the English language for communication here.
MaviATES
Post by MaviATES » Wed Mar 24, 2021 8:14 am
Greetings from Turkey. I had the same situation as well, but I solved the problem. It is not related to DLL files of the operating system. It will be fixed if you make the following change to a setting in power options.
Control Panel> Power Options> Change plan settings> Change advanced power settings> Switchable Dynamic Graphics> General Settings
Under this option, there are two options: Plugged in and On Battery. Bring both to the "Maximize performance" option. Apply and save saying OK.
You will see the program open when you try it now. If you change the power setting, don't forget to set the same action in it.
I am using Windows 10 in Turkish. I took screenshots and added them in case you had trouble applying them.
MaviATES
Post by MaviATES » Wed Mar 24, 2021 8:16 am
The continuation of the first message, as a maximum of 3 pictures can be added .
Return to “FreeOffice Presentations 2018 for Windows”
