Command Line Options to run .pptx?
Questions and answers about FreeOffice Presentations 2018 for Windows
Obsolesce
Post by Obsolesce » Fri Aug 24, 2018 6:45 pm
Hello,
What are the command line options for opening a presentation?
For example, with LibreOffice, I would simply type the following, which automatically opens the presentation in "show" mode. This is a must have feature! How can I do this in FreeOffice?
Code: Select all
soffice --show --invisible --norestore /home/user/Desktop/presentation.pptx
The reason I want to do this in FreeOffice Presentations is because Libre/Open Office do not load the PowerPoint settings correctly, but FreeOffice does!
Thank you!
Re: Command Line Options to run .pptx?
Post by martin-k » Sat Aug 25, 2018 7:59 am
I have moved your post to the FreeOffice Presentations fourm.
Try this:
Code: Select all
presentations18free -sFILENAME.pptx
Obsolesce
Post by Obsolesce » Sat Aug 25, 2018 10:34 pm
Thank you, I am currently traveling so I will not be able to try it until Wednesday. I will respond then with the results.
Return to “FreeOffice Presentations 2018 for Windows”
