Cell properties settings not saved
Questions and answers about FreeOffice PlanMaker 2018 for Windows
Léon
Post by Léon » Mon Apr 12, 2021 9:44 am
A cell with an extremely simple formula (=B2-B1) changes from Number (also very simple) to Custom after every closing of the worksheet. Custom then says 0.0;[Red]/0.0.
This happens when I choose the option "Negative values in red".
When I open the worksheet it does not just say -2,5 in red, but /0.0. (In red).
What is this and how do I solve it? Or: what am I doing wrong?
Re: Cell properties settings not saved
Post by SuperTech » Thu Apr 22, 2021 4:54 pm
Thanks for reporting this problem. Please share the associated file of PlanMaker in which you are getting this problem so that we can do further investigation for resolution.
viewtopic.php?f=318&t=21041
Léon
Post by Léon » Thu Apr 22, 2021 7:15 pm
E-mail has been sent.
Post by SuperTech » Mon Apr 26, 2021 6:21 pm
Thanks for sharing the file. Please follow these steps to resolve this problem:
1. Please right-click on Cell B6, click on option Cell....
2. Under Number format tab select Number.
3. On right side check/enable option "Negative numbers in red".
4. Click OK.
5. Save and re-open this file.
I have already tried and tested above steps.
Léon
Post by Léon » Mon Apr 26, 2021 8:33 pm
Hello SuperTech,
What you describe is exactly the problem:
I did this (of course) 20 times and at the next opening of the document the cell is back to wrong. You could read this in the original question.
Post by SuperTech » Wed Apr 28, 2021 9:03 pm
I was able to reproduce this problem when changed the interface language to Nederlands. I have forwarded the details to our developers team for further investigation.
Return to “FreeOffice PlanMaker 2018 for Windows”
