Sidebar question
Questions and answers about FreeOffice PlanMaker 2018 for Windows
Sidebar question
Post by Woody44 » Mon Sep 07, 2020 11:01 am
In TextMaker and Presentations, using the classic menu I can go to the 'View" menu and hide the sidebar.
That doesn't work in PlanMaker. Is it possible to hide the sidebar in PlanMaker? If so, how?
Re: Sidebar question
Post by martin-k » Mon Sep 07, 2020 1:31 pm
No. You can resize it however.
Post by Woody44 » Mon Sep 07, 2020 4:40 pm
Oops.
That worked -- too well. It's gone, which is what I wanted. But how do I get it back if I want/need it?
MisterEd
Post by MisterEd » Sat Nov 14, 2020 4:55 am
On the left center side of the Sidebar there is a thin button.
Clicking on the button will toggle closing and opening the Sidebar.
w1nt
Post by w1nt » Sun Apr 04, 2021 10:27 am
This sidebar matter is very odd. In my version of Freemaker, I can't stop either Textmaker or Planmaker from launching with the sidebar open: presumably it does this because it carries advertising for the paid Softmaker. In both programs, I can hide the sidebar either by dragging the border (between the program window and the sidebar window) to the right, or double-clicking on the tiny tab in the middle of the program/sidebar divider. In Textmaker I can also use View / Sidebar / Hide but in Planmaker the Hide option in View / Pivot Table Sidebar is greyed out and unavailable.
The situation is the same if I close the sidebar window and the save the document as my default template.
I suppose this is just inconsistent programming in a free version of the product?
Post by SuperTech » Mon Apr 19, 2021 11:18 am
As these are free applications, showing advertisements from time to time is normal, which you also confirmed that you can close easily.
Return to “FreeOffice PlanMaker 2018 for Windows”
