Basic stubling at Square Zero
Questions and answers about FreeOffice PlanMaker 2018 for Windows
ChrisWesley
Post by ChrisWesley » Wed Feb 05, 2020 1:12 pm
I want to see how to edit range names.
I've done it before, but I can't find it now.
So the help document says:
To assign a name to a range of cells:
1. Select the cell range that you want to name.
2. Choose the menu command Worksheet > Names > Edit.
3. Input a name for the cell range in the Name edit control.
- But where is the "Worksheet" it is referring to?????
I can see a menu bar with File, Home, Insert, Layout, etc.
But I cannot see a Worksheet menu item.
I'm braced for being proved incredibly dumb, but I need otget past this, so if that's what it takesa, I'll take, it.
Anyone?
Re: Basic stubling at Square Zero
Post by miguel-c » Fri Feb 14, 2020 3:49 pm
Worksheet > Names > Edit is the menu structure of the classic menu.
At the end of the user manual, there's a list of correspondence between the classic menu and the ribbon of icons.
You are using the Ribbon of icons you can access it via Formula | Edit names
OR you can access via the hamburger classic menu:
Return to “FreeOffice PlanMaker 2018 for Windows”
