Remove Duplicate Entries
greeness
Post by greeness » Fri Sep 07, 2018 3:26 pm
I am unable to locate a command that will remove duplicate entries. The manual says to use the command "Table > Remove > Duplicate Rows" but I am unable to locate the duplicate rows command. Where will I find this?
Re: Remove Duplicate Entries
Post by sven-l » Mon Sep 10, 2018 10:56 am
That's at least how it worked until PlanMaker 2016. In PlanMaker 2018 (if you use the Ribbons, you have to click on Data | Remove empty rows.
Please note: This feature is not available in FreeOffice 2018.
Return to “FreeOffice PlanMaker 2018 for Windows”
