Planmaker losting rotation
Questions and answers about FreeOffice PlanMaker 2018 for Windows
InfoMan
Post by InfoMan » Mon Sep 03, 2018 7:27 pm
I have used the FreeOffice 2018 Softmaker. It really is an excellent product. It has a high level of compatibility with Microsoft Office and opens its files almost perfectly.
I realized a mistake and I'd like you to sort it out, please.
We have some Excel spreadsheets that contain bar graphs and the Values ​​Axis Title is rotated by 90 degrees.
Opening these files loses the 90 degree rotation of these files and the program formats without rotation, that is, zero degrees.
Even if I correct the rotation and save the corrected file, when I reopen the file it continues without rotation, ie, the correction is lost.
Please fix this.
Thank you very much for your attention.
Re: Planmaker losting rotation
Post by sven-l » Tue Sep 04, 2018 1:11 pm
Please attach a sample file or send it to forum(at)softmaker.com referring to this thread.
InfoMan
Post by InfoMan » Tue Sep 04, 2018 2:54 pm
As requested I am attaching files for demonstration of error.
The two image files show the difference in opening between the two programs.
I've also attached a file in Excel 2010 so that I can analyze the problem.
Freeoffice Erro.xlsx
File created in Microsoft Excel 2010 for demonstration of this error.
(13.93 KiB) Downloaded 61 times
File opened in Freeoffice
File created and opened in Microsoft Excel 2010.
Post by sven-l » Wed Sep 05, 2018 10:28 am
Thank you! I will test it here and inform the developers.
InfoMan
Post by InfoMan » Thu Sep 06, 2018 12:25 pm
Thank You Very Much,
Post by sven-l » Mon Sep 10, 2018 1:46 pm
This problem has been solved and should no longer occur in the next update of FreeOffice.
InfoMan
Post by InfoMan » Mon Sep 10, 2018 1:57 pm
OK. Thank you very much for your attention and for correcting this error. I'm really glad about it.
Return to “FreeOffice PlanMaker 2018 for Windows”
