How to select text of same format?
Hi, I'm trying to find out if Textmaker has the feature of selecting text of same format in a document? In MS Word, for example, there is a submenu under "SELECT" that offers "Select all" or "Select text of same format". I would prefer to use Textmaker instead of MS Word, but I need this feature and cannot find it here. Thank you!
Re: How to select text of same format?
Thanks for your suggestion. I tried to check this option "SELECT" in Word for Android but unable to find such feature. Please share a screen recording of it for better understanding of this feature.
To search for styles, go to Edit > Search... and then click the button "Format..."
