printing an envelope with Free Office
Post your questions, bug reports and suggestions here for FreeOffice TextMaker 2018 for Windows.
Swinden
Post by Swinden » Wed Jul 17, 2019 1:23 pm
I've been searching in Softmaker's Free Office for a possibility to print an envelope (adresses and sender), couldn't find it.
Is it possible anyway and if so, where can I find it?
Thanks!
Re: printing an envelope with Free Office
Post by martin-k » Wed Jul 17, 2019 1:26 pm
SoftMaker Office has an envelope function for this purpose.
In FreeOffice, you need to create your document manually: set the page size to the size of your envelope, insert text frames for sender and recipient, fill the text frames. You can save the result as a template for future use.
Swinden
Post by Swinden » Wed Jul 17, 2019 1:48 pm
OK, I'll do that.
Thanks for the explanation.
