templates save as not working?
Questions and answers about FreeOffice TextMaker 2018 for Windows
violindave
Post by violindave » Wed Jan 09, 2019 2:51 pm
New to textmaker
I opened normal template in textmaker
Changed the font size from 10 to 12
Saved as new name under templates
Set it as default, registry was changed
Opened a new document, which opened with the new template name but the font size was the original font size
How do I get TM to save the changed font size in the template and use this as default. Also so that if I use the new icon on toolbar it will open with this new template automatically
Thanks for your help!
Re: templates save as not working?
Post by Jossi » Wed Jan 09, 2019 5:00 pm
If you simply change the font size, only the occurence in this specific place is changed. To make a permanent change, you have to change the corresponding character style via Format > Character style...
violindave
Post by violindave » Wed Jan 09, 2019 7:44 pm
Thank you!! that worked!!
Appreciate the help
