Problem with table height
Questions and answers about FreeOffice TextMaker 2018 for Windows
Suono & Computer
Post by Suono & Computer » Mon Nov 19, 2018 11:50 am
I can not create a table with a height of less than 0.7 cm for a single cell. Why? Thank you.
https://www.youtube.com/watch?v=rujEMnD ... e=youtu.be
Suono & Computer channel on YouTube
Re: Problem with table height
Post by sven-l » Thu Nov 22, 2018 11:27 am
The table row height is set to "At least" by default. This means that the minimum heigh cannot be smaller than your used font size. If you reduce the font size (e.g from Times New Roman 10pt to Time New Roman 6pt) you can use a smaller row height.
Change the height in the row properties from "At least" to "Exact" if you want to reduce the table row height to 0.1 (minimum in TextMaker).
