Collapsible Paragraphs or Anchor Links
Questions and answers about FreeOffice TextMaker 2018 for Windows
lexi
Post by lexi » Mon Oct 15, 2018 4:14 pm
Having long documents and given the sequential nature of word processors makes it difficult to focus and quickly find parts of the document.
It would be great to be able to collapse paragraph boxes (good for organizing ideas) since text frames are not as easy to handle.
You only have to put a border around the desired paragraphs and being able to collapse them makes a lot of sense.
If that's not possible, how do you create an hyperlink to take you to a specific paragraph? (like anchor links in HTML)
Re: Collapsible Paragraphs or Anchor Links
Post by sven-l » Fri Oct 19, 2018 3:21 pm
The full version, SoftMaker Office 2018 has an outliner for that purpose.
lexi
Post by lexi » Sun Nov 11, 2018 3:22 pm
Tried the outliner and it requires a change in view. Changes in outliner mode (promotions/demotions) modified the document in my preferred view. Outliner view is not appealing and requires more work.
You should consider creating a "collapsible box" button/functionality that operates just like the current box and looks mostly the same, but is collapsible.
