Changing the default font for all documents
Questions and answers about FreeOffice TextMaker 2018 for Windows
mike21
Post by mike21 » Fri Aug 03, 2018 9:10 pm
How do I edit the "normal" template to change things such as font size, and where is the template stored. I cannot find itunder Help or Options
raitis.veksejs
Re: Changing the default font for all documents
Post by raitis.veksejs » Tue Aug 07, 2018 10:54 pm
Hello!
You should find folder C:\Users\<User Profile>\Documents\SoftMaker\Templates 2018\<Your Language>.
Then open template file Normal.tmvx in TextMaker and edit Styles for which you need to use another formatting.
P.S. Default font for all new documents you can set also as shown in the screenshot attached here.
mike21
Post by mike21 » Fri Aug 10, 2018 5:25 pm
Thank you for your reply, I have only just been able to get online again and see your response.
When I click on normal.tmvx in the path you give it opens as "untitled 1" not as normal.tmvx - I have also failed with the second method in that I cannot bring up the screen you illustrate headed Attachments - it does not appear in any of the sub-menus. Under the normal.tmvx properties I have full permissions - file size is 7.75 kb
raitis.veksejs
Post by raitis.veksejs » Sat Aug 11, 2018 12:04 am
You should open template file Normal.tmvx in TextMaker through File>Open dialogue and then make changes.
mike21
Post by mike21 » Sat Aug 11, 2018 12:19 pm
Thank you again. I have finally managed to make changes.
