Fit text to cell
Questions and answers about FreeOffice TextMaker 2018 for Windows
wbrells
Fit text to cell
Post by wbrells » Sun Jun 24, 2018 2:22 pm
I'm using a Python program to generate a DOCX file that contains a multi-page table of names and addresses. Some entries are too long to fit within a table cell so I'm (programmatically) using Word's "fit to cell" option to shrink text appropriately to make everything fit. The resulting DOCX file looks fine when I examine it with Word 2007, but with TextMaker 2018 the over-length text is not being compressed and flows over to the next line - not good! INTERESTINGLY, all is well if I read the original program-generated DOCX file with Word 2007 and then save it under a new name (but still in DOCX format). This saved file is about 25% larger than the original DOCX file but the compressed entries are now fine in both Word 2007 and in TextMaker 2018.
I'm not sure what to make of this behavior, but at least there is a workaround to get "fit to text" working in TextMaker 2018. It would be nice, though, if I did not need Word 2007 to create a file that works correctly with TextMaker. Any thoughts/comments would be welcome!
Wayne
Re: Fit text to cell
Post by sven-l » Tue Jul 03, 2018 4:16 pm
Please attach a sample docx file or send it to forum(at)softmaker.com.
wbrells
Post by wbrells » Thu Jul 05, 2018 12:55 am
I'm sorry for not responding earlier, but it took a little time to generate a small test DOCX file with names and addresses obscured. In any case, please examine the attached DOCX file with MS Word and notice on Page 3 the fit-to-cell entries of PAT: and PHYL:. Now take a look at the same file with TextMaker and notice that those entries are "full size" and overflow the cell. However, if you save the file as a new DOCX file using MS Word that new file will:
1) Be somewhat larger
2) Will be correct when opened with TextMaker
As I mentioned, it would be convenient if TextMaker displayed the original DOCX file appropriately...
Thanks,
Wayne
Residents-by-Address.docx
Generated by a Python program
(12.18 KiB) Downloaded 79 times
Post by sven-l » Mon Jul 09, 2018 4:16 pm
Thank you! I can now reproduce that issue here and will inform the developers.
wbrells
Post by wbrells » Sun Oct 14, 2018 11:58 am
Sven,
Unfortunately, the latest service pack does NOT seem to have fixed this "Fit text to cell" problem. Can you check with the developers and make sure they are - hopefully - working on a fix?
Thanks,
Wayne
Post by sven-l » Fri Oct 19, 2018 3:22 pm
What you are requesting is not a bug but a missing feature. I put it on the wish list.
wbrells
Post by wbrells » Fri Oct 19, 2018 9:25 pm
I only considered this a "bug" since a particular DOCX file is displayed differently in Textmaker than in Word 2007. Since TextMaker doesn't seem to support the "Fit text to cell", I guess my comments could be considered a request for an enhancement. However, since TextMaker does allow character pitch and spacing to be adjusted it would seem that it should be able to "translate" Word's "Fit text to cell" option into the appropriate character spacing option(s)....
Wayne
wbrells
Post by wbrells » Sun Sep 29, 2019 3:05 pm
Just checking to see if there has been any progress on adding the 'fit to cell' option to FreeOffice and/or Softmaker Office? This feature has been in Word for a long time, and it is EXTREMELY useful when text MUST be confined to a single line of a table cell.... Thanks!
Post by miguel-c » Sat Oct 12, 2019 7:54 pm
Sorry, there are no developments yet on that feature request.
Post by Woody44 » Tue Feb 18, 2020 2:17 am
I am curious whether or not any progress has been made on this. It seems important.
Maybe this is semantics, but wbrells called it a bug, and sven-l responded that it's "not a bug but a missing feature." But the web page for Free Office explicitly says " It is seamlessly compatible with Microsoft Office ..." I don't think it's semantics to point out that when Free Office is advertised as "seamlessly compatible with Microsoft Office" but then Free Office can't handle a document created in Microsoft Office -- that's not "seamlessly compatible." If it's supposed to be seamlessly compatible but it isn't -- that's a bug, not a missing feature.
Please don't misunderstand. I like Free Office (and Softmaker Office for Android), and I dislike Microsoft's new (well, not so new, now) ribbon interface. I love that Softmaker gives the user the option of which interface he/she wants to use. Unfortunately, when seamless compatibility isn't seamlessly compatible, that just means that it's not yet safe to dump Microsoft and make the jump to Softmaker. This means that I maintain both Microsoft Office and Softmaker Office on my Android tablet, and I maintain Microsoft Office 2003 and 2016, plus both Free Office and Libre Office on my desktop computer. I have to do that because I can't stand the ribbon interface, but I have to be absolutely certain that documents, spreadsheets, and presentations I create will be 100% compatible with clients' systems.
