Hiding Backup Files
General questions and answers about FreeOffice 2018 for Windows. Don't post application-specific questions here, but in the appropriate subforum.
Fabled Pilgrim
Hiding Backup Files
Post by Fabled Pilgrim » Mon Mar 29, 2021 2:26 pm
As the title suggests, I would like to be able to have the backup facility without the *.bak files showing in the same folder as the *.doc file. If I have 20 documents in a folder it becomes 40 as each one has it's own *.bak file with duplicate filename.
It's not the end of the world but it would be nice if there was a way to hide them to make it easier to locate files I need.
Any suggestions?
Re: Hiding Backup Files
Post by martin-k » Mon Mar 29, 2021 3:27 pm
I moved this to the FreeOffice forum since you are talking about FreeOffice.
Post by SuperTech » Thu Apr 08, 2021 8:31 pm
This is not feasible in FreeOffice but in commercial version SoftMaker Office 2021, we can set folder path for the file versions for backup.
Fabled Pilgrim
Post by Fabled Pilgrim » Wed May 05, 2021 3:39 pm
Ok, thanks for your reply.
Return to “SoftMaker FreeOffice 2018 for Windows (General)”
