Activation Each Run
General questions and answers about FreeOffice 2018 for Windows. Don't post application-specific questions here, but in the appropriate subforum.
indogo
Activation Each Run
Post by indogo » Fri Jun 26, 2020 12:38 pm
Have used Freeoffice in the past....neat fast software thank you :)
I decided to try freeoffice 2018 , latest build from your website on windows 7.
The activation request came a few days later and I got a key but it seems I have to enter it each time I run any of the programs.
Is this normal behaviour now?
mike
Re: Activation Each Run
Post by SuperTech » Fri Jun 26, 2020 1:46 pm
Thanks for reporting this issue. No, this is not usual, please share a screenshot of the screen which you getting first after opening the program.
indogo
Post by indogo » Sun Jun 28, 2020 10:17 am
I do enter the key using the link....last done it two days ago.
Planmaker and presenter are the same.
thank you
mike
Post by SuperTech » Sun Jun 28, 2020 7:04 pm
It seems SoftMaker Office cannot save the license file. Delete the folder c:\ProgramData\SoftMaker and try again.
indogo
Post by indogo » Mon Jun 29, 2020 10:34 am
Tried that still the same plus days left did not change.
Cannot change folder from read only either though contained files are not. Delete did delete.
mike
Post by martin-k » Mon Jun 29, 2020 10:47 am
The left-over .tmp file indicates you don't have full access rights to this folder.
indogo
Post by indogo » Tue Jun 30, 2020 5:46 am
Hmm permissions seem to be involved but various attempts to give control seem to not help.
I am logged in as admin.
I cannot spend more time on this for now but thank you for clues.
regards
Mike
Post by SuperTech » Tue Jun 30, 2020 10:38 am
As you can see there is a lock icon on this folder which shows there are some security issues with this folder. Please right-click and correct the security settings of this folder.
indogo
Post by indogo » Wed Jul 01, 2020 8:14 am
I did notice in the beginning that but nothing would change permissions.
I tried to install on a fresh windows 64 install and activation worked so indeed there is a permission problem.
As it happens I renamed the .tmp file to .lic and now its activated. Also the lock has gone in doing so!
Thank you for your help.
regards
mike
Return to “SoftMaker FreeOffice 2018 for Windows (General)”
