The shortcuts
General questions and answers about FreeOffice 2018 for Windows. Don't post application-specific questions here, but in the appropriate subforum.
DenisC
The shortcuts
Post by DenisC » Wed Jul 17, 2019 11:14 am
Hello,
I'm trying to figure out how to create shortcuts.
For example, to insert the current date, in Excel the combination is: Ctrl + Shift + ;
Can we do the same in FreeOffice 2018 and if so how ?
Thank you in advance for your answers.
Denis
Re: The shortcuts
Post by miguel-c » Wed Jul 17, 2019 11:40 am
Hi, currently in PlanMaker CTRL+. inserts the current date and CTRL+SHIFT+. inserts the current time.
In FreeOffice, you can't customize the keyboard. In the commercial version, SoftMaker Office, proceed as follows:
In order for you to customize keyboard shortcuts:
1. right-click the ribbon of icons > Customize Ribbon... > Quicksearch
2. Type "date" in the box (without the quotes).
3. See the current shortcut at the bottom and add a new one if needed
DenisC
Re: The shortcuts
Post by DenisC » Fri Jul 19, 2019 10:31 am
Hi
Thank you very much for the answer. :D
Problem solved.
Return to “SoftMaker FreeOffice 2018 for Windows (General)”
