Associations
General questions and answers about FreeOffice 2018 for Windows. Don't post application-specific questions here, but in the appropriate subforum.
earleib
Associations
Post by earleib » Mon Jun 04, 2018 6:12 pm
I just finished installing SoftMaker FreeOffice 2018 on my HP desktop with Windows 10 (with the April update). When setting the options (Tools/options/system) I found that when trying to set "associate file types" and I click the box, something flashes in the background and it brings up Windows settings. I tried the same thing on Softmaker FreeOffice 2016 and got the same results. I then went to my HP laptop and Windows 10 (with the April update) also with SoftMaker FreeOffics 2016 and got the same thing. I'm almost positive that when I installed the 2016 version, I had no problem setting up the associations. What am I missing? Is there a compatibility problem here? If so, what can I do?
Re: Associations
Post by martin-k » Mon Jun 04, 2018 7:43 pm
This is not a bug, at least not ours. There is no way to bring up the Windows File Association dialog in the foreground. Microsoft never bothered to fix it, but it is the only way these days to set file associations from an application. You need to bring the dialog to the foreground yourself.
earleib
Re: Associations
Post by earleib » Mon Jun 04, 2018 11:28 pm
I am not trying to bring up Windows file associations, I am trying to associate SoftMaker files from within SoftMakers: tools - options - system - "associate file types" . From the system tab, when you click on the rectangular box mid way down on the left side that says "associate file types". I used to be able to set all the associations for Softmaker. I can't do that any more.
Re: Associations
Post by martin-k » Mon Jun 04, 2018 11:54 pm
The only way to set file associations with Windows 10 forward for an application is to bring up the file-association window of the system, and that's what SoftMaker Office does. An application can no longer ask to register file associations, it can only let the user do it through this window.
Return to “SoftMaker FreeOffice 2018 for Windows (General)”
