Prompts for Product Key, Doesn't Allow Registration for Key
Post your questions, bug reports and suggestions here for Presentations 2018 for Mac.
etcomro
Post by etcomro » Fri Aug 09, 2019 11:21 pm
Can anyone help with this? I open it for the first time after downloading and I'm prompted to get a free product key. I enter in my email and it says it can't connect to the server and to check network connection. My internet is working so what's the deal? Thanks.
Re: Prompts for Product Key, Doesn't Allow Registration for Key
Post by miguel-c » Sun Aug 11, 2019 8:15 pm
Hi, please turn your firewall off (temporarely) or add shop.softmaker.com to your firewall whitelist. Then try again
etcomro
Post by etcomro » Sun Aug 11, 2019 9:19 pm
I checked, firewall is off and still not working.
I'm running MacOS 10.10.5 if that matters.
Robbot
Post by Robbot » Mon Aug 12, 2019 3:33 pm
same problem, tried everything. no connection and no free key. 4 days left.already looking for backup so i can run my presentation. worked 3 days on it.
Robbot
Post by Robbot » Mon Aug 12, 2019 3:35 pm
same here. tried everything. 4 days left. worked 3 days on presentation. looking already for backup.
Post by miguel-c » Mon Aug 12, 2019 3:39 pm
Are you also with macOS 10.10?
Robbot
Post by Robbot » Mon Aug 12, 2019 5:02 pm
using mac 10.11.6 also tried to make an update can not connect to soft maker.com
Post by miguel-c » Mon Aug 12, 2019 7:04 pm
Hi, I've forwarded your activation issues to the developers. Thank you
Post by miguel-c » Mon Aug 12, 2019 10:21 pm
Hi, I need the following from the people who are having this issue:
1. What Office suite you are running? SoftMaker Office or FreeOffice?
2. What version do you have? 966?
3. Please send us a screenshot with the error message
4. Make sure you whitelist licensing.softmaker.com or disable your firewall
5. MacOS version
Thank you
Christine Chang
Post by Christine Chang » Wed Aug 28, 2019 1:00 pm
same here.
Return to “Presentations 2018 for Mac”
