Can't save as xlsx
Sprite9
Can't save as xlsx
Post by Sprite9 »
Attempting to save spreadsheet with .xlsx extension results in .pmdx being saved. Planmaker Professional 2018 (974.0203) 64 Bit on macOS 10.15.3.
Sprite9
Re: Can't save as xlsx
Post by Sprite9 »
I solved this. My filename is long so I didn't see in the filename save as dialog that there was a .pmdx extension. This appears to not change even if I've selected to save as .xlsx and it appears that the filename extension has priority over the save as selection. Manually changing the filename ending to .xlsx and selecting save as .xlsx worked.
I was able to reproduce the issue and reported it to the developers. Thanks!
Return to “PlanMaker 2018 for Mac”
