Manage PlanMaker Currency Display
Wondering
Post by Wondering »
I am on an extended stay in Portugal having travelled from the United States. I am using the purchased version of SoftMaker Office 2018 for Mac on a MacBook Pro laptop. I have changed my time zone setting to Portugal. I do not know whether changing the time zone setting has anything to do with my issue, but the issue is PlanMaker now displays currency like this: $1 000,00 instead of what I have always seen in The States as $1,000.00. What MacBook Pro or PlanMaker setting do I need to navigate to in order make a setting that will have currency displayed in the fashion that is most familiar to me, i.e. $1,000.00. Thank you for your help.
Re: Manage PlanMaker Currency Display
Hi, I wasn't able to reproduce the issue you describe (MacOS 10.14.6 and PlanMaker 970).
My test setup was:
1: MacOS regional settings: United States
2: MacOS timezone: New York EST.
3. I then changed the timezone from New York to Lisbon
4. Opened PlanMaker. The currency was still $1,000.00
In order for you to change the decimal separator:
1. Open macOS's spotlight and search for region
2. Change to United States
3. Click Advanced... You'll see the decimal separator there.
4. Open Planmaker
Wondering
Post by Wondering »
Muitu Obrigad Miguel,
The advanced button under "Language & Region" in Mac OS gave me a "Numbers separator:" option field where I was able to set the "Decimal" to a dot / period and then SoftMaker PlanMaker reflected the change. It then caused the "Region" field to report "Portugal (Custom). Did the trick. Thanks again for helping me feel comfortable.
I hope you enjoy your stay :-)
Return to “PlanMaker 2018 for Mac”
