Cannot open CSV after SMO saved it as XLSX
Post your questions, bug reports and suggestions here for PlanMaker 2018 for Mac.
romraptor
Post by romraptor » Mon Jun 03, 2019 4:06 pm
Hi! I had some Excel spreadsheets at work that I brought home (CSV files made in Excel containing nothing more than some text).
They open fine in PlanMaker so I edited some text and clicked Save. PlanMaker then saved them as XLSX.
Lastly, I brought the XLSX files back to work, but unfortunately Excel wasn't able open them. Said something about wrong format. Renaming to CSV didn't help either.
Re: Cannot open CSV after SMO saved it as XLSX
Post by miguel-c » Wed Jun 05, 2019 7:06 pm
1. Could you please send us a sample csv and xlss file to forum(at)softmaker.de referring the URL of this thread?
2. Please go to ? > About and let us know the revision of your software. The latest is 962.0418
romraptor
Post by romraptor » Wed Jun 05, 2019 7:47 pm
I've sent an e-mail now.
Post by miguel-c » Wed Jun 05, 2019 8:22 pm
I was able to reproduce the issue you described.
I'm going to report it to the developers and will let you know when it's fixed.
Thank you for your feedback!
Post by miguel-c » Thu Jun 06, 2019 10:57 am
Hi, the issue was fixed and will be available in the next service pack.
In the meanwhile, the solution is simple: rename the .xlsx extension to .xls or do a save as xls in PlanMaker
romraptor
Post by romraptor » Thu Jun 06, 2019 11:14 am
Thanks!
Return to “PlanMaker 2018 for Mac”
