Locking Up on Scrolling With Multiple Windows
If I have two or more documents (file type does not appear relevant) opened in TextMaker 2018 in individual windows and I attempt to scroll on one of them, all TextMaker windows will freeze for maybe 30 seconds before the scrolling in the one window finally happens and then I can interact with controls or the document again. This may only happen once per opened and scrolled document.
						Re: Locking Up on Scrolling With Multiple Windows
I tried to reproduce this issue in openSuse Leap 42.3 64bit but there is no delay when I scroll in any of the open documents (opened in different program instances of TextMaker).
Which Linux and TextMaker revision (Help=>About) are you using? Does it happen with all files (even new created ones)? Do the files contain a lot of graphics?
This happens on TextMaker 2018 rev 928.0313 64bit on Debian 9.4 64bit. It does not seem to matter if it is a new file or how much text/graphics there are.
Could you please send us the sminfo.txt (logfile) you can create in the Help=>About dialog to forum(at)softmaker.com?
Sent, thank you!
