Hi !
The copy/paste feature seems not yet fully fixed with the official release.
I tried on OpenSUSE 42.3, Firefox & Chrome, same issue.
Example :
Link : https://aulnaycap.com/2018/02/12/le-rap ... -avec-xeu/
Select from : before "Le rappeur" (the title) to "Generation.fr", and copy
In LibreOffice writter : no big issue, the image is copied
In Textmaker : some font issues, the image not copied
Is it related to something specific to my desktop or does anybody else encounter the same issue ?
Thanks,
Regards
Copy/Paste issue with TextMaker
Re: Copy/Paste issue with TextMaker
Which browser are you using? We had an issue with pasting images together with text from Fireforx into TextMaker (ticket 37773) but it was reported as resolved.
Hi !
I used Firefox but tried also with Chrome. Approximately same results even if the rendering varies a little bit.
Are you able to replicate the issue ?
Yes, I can confirm that the image is not pasted. I will report this to the developers. Thank you!
