Yet Another Menu Question [FIXED]
Post here those questions, bug reports and suggestions for SoftMaker Office 2018 for Linux that do not fit in any of the application-specific subforums.
cpcnw
Post by cpcnw » Sat Oct 26, 2019 5:32 pm
Hi
Is it possible under linux to influence /change the font on the toolbar and the drop down menus?
Thanks!
cpcnw
Re: Yet Another Menu Question
Post by cpcnw » Sat Oct 26, 2019 10:27 pm
Turns out there is a control in SMFO - Tools > Option > Appearance > User Interface > Use System Fonts
Which makes the size more to my liking however I cannot change the actual font used there?
In one of the program directory i found gui.txt and it suggests moving it to the app directory and making changes there.
Where is the spec for the following? I got it to accept Arial but want to take the bold off.
[General]
// menu font
menuFont=Arial,8,-1,5,50,0,0,0,0,0
// font for dialogs
font=Arial,8,-1,5,50,0,0,0,0,0
dhalgren
Post by dhalgren » Sun Oct 27, 2019 4:49 am
If you are using Gnome, you can change it all buy using Gnome Tweak Tool.
I don't use gnome but I found that out by accident when I forgot to prevent netinstall puling in Gnome.Consequently I had to have a play with it, and ended up with TM looking like the screenshot, even after I uninstalled most of Gnome. (I am using Bunsenlabs openbox, so I have to run TM with the switch -gui:gnome so it keeps the changes to the menus made by the gnome tweak tool. I also have to select "use system fonts" in the user interface selection, or it is grubby horribleness.)
The changes to the menu fonts are also within the hamburger menu, and this may be what you want.
Hope this helps.
cpcnw
Post by cpcnw » Mon Oct 28, 2019 5:02 pm
Hey - that '-gui:gnome' switch did the trick!!!
Thanks!
cpcnw
Re: Yet Another Menu Question [FIXED]
Post by cpcnw » Mon Oct 28, 2019 5:18 pm
Also adding
! xft settings !
Xft.antialias: 1
Xft.autohint: 0
Xft.dpi: 96
Xft.hinting: 1
Xft.hintstyle: hintfull
Xft.lcdfilter: lcddefault
Xft.rgba: rgb
to .Xresrouces
dhalgren
Post by dhalgren » Mon Oct 28, 2019 10:03 pm
Happy to hear the switch worked for you.
I have never had to edit .Xresources for fonts, but that is good to know for the future. Thanks.
cpcnw
Post by cpcnw » Tue Oct 29, 2019 9:43 pm
Also check > Tools > Options > Appearance > Smooth Edge of Screen Fonts
dhalgren
Post by dhalgren » Thu Oct 31, 2019 12:53 am
Oh yes, I've set that one.
The Bunsenlabs font configuration is very good, however, and I have never had to play with ~/.Xresouces to fix any font configuration issue.
