after installing SoftMaker Office on lubuntu does not open
Post here those questions, bug reports and suggestions for SoftMaker Office 2018 for Linux that do not fit in any of the application-specific subforums.
sxnii
Post by sxnii » Fri Aug 09, 2019 2:22 pm
Hello, I am new with SoftMaker Office and I have installed it on my pc with Lubuntu 18.04LTS and after the installation is finished and I am going to open the text maker or another one makes it open but does not open. That I have to do?
a greeting
Re: after installing SoftMaker Office on lubuntu does not open
Post by miguel-c » Fri Aug 09, 2019 6:55 pm
Hi, could you please do the following?:
1. open a terminal window
2. run the following command: TextMaker18 -debug
3. then send us the file /root/SoftMaker/Settings/tmlog.txt
Thank you.
sxnii
Post by sxnii » Sun Aug 11, 2019 12:18 pm
Thank you.
I have entered the command and it tells me order not found
Post by miguel-c » Mon Aug 12, 2019 12:00 am
On my Ubuntu it''s under ./usr/bin/textmaker18
You may:
cd /
find -name textmaker18
