Hello
I have a project where I will be working away from the office.
I need a computer I can carry with me. I have an old netbook, but it's not very powerful. 900Mhz (single core!) processor, 512MB Ram.
Will Textmaker work on it, or is it too old?
Smallest amount of RAM for a nicely operating Textmaker
colonel_panic
Re: Smallest amount of RAM for a nicely operating Textmaker
I don't think anyone here knows, apart from Sofmaker staff and devs. The only thing I could find were operating system requirements.
Why don't you just install and see if it runs? That is what I would do.
colonel_panic
I was thinking that one would have been in touch.
It would be a bit of fiddling to recomission the computer. I have no idea what OS is on there at the minute.
I will install it on a virtual machine and report back. Thank you!
Hope it works for you colonel_panic.
And surely it will run BL? (I am assuming you are the colonel panic from the BL forums, if you are not, then my apologies for the assumption.)
colonel_panic
Oh, small world! Yes, it is me on the BL forums. A silly joke from when Linux was easier to get wrong, but it made me smile.
