Thunderbird Extensions
Post here those questions, bug reports and suggestions for SoftMaker Office 2018 for Linux that do not fit in any of the application-specific subforums.
stustones
Post by stustones » Tue Mar 06, 2018 1:50 pm
Hi all,
I've just downloaded the trial of Office 2018 for Linux - so far it's impressed me with MS Office compatibility, as well as the look-and-feel, so all good there. My question though relates to Thunderbird - the SoftMaker website advertises the Extensions for Thunderbird, including MS Exchange compatibility - which is a feature I'd really like to try...
http://www.softmaker.com/en/softmaker-o ... hunderbird
... however the extensions don't seem to be part of the trial, only the "normal" Thunderbird is installed on my Linux machine, no SoftMaker extensions. Do I have to download these separately? or do I only get them after purchasing the product (ie not in trial?).
Many thanks,
S.
Re: Thunderbird Extensions
Post by sven-l » Tue Mar 06, 2018 3:17 pm
The Thunderbird extensions are also included in the trial version but not installed by default. In /home/SoftMaker, you will find a readme file with an installation instruction.
stustones
Post by stustones » Tue Mar 06, 2018 3:51 pm
Hi Sven,
Thanks for your reply! I've installed the SoftMaker Enhanced UI and Messaging Menu (Theme), but when adding my Exchange account, I still only get the options for IMAP and POP3.
How can I add an Exchange account? Or have I missed something obvious?
Cheers,
S.
Post by sven-l » Fri Mar 16, 2018 3:54 pm
Thunderbird does not support Exchange accounts by default but there are Add-ons available:
https://support.mozilla.org/de/questions/1176527
joedanmark
Post by joedanmark » Sat Nov 24, 2018 2:45 am
Just a note - According to the Readme for the linux installation step 3 , It states 3. "In the add-on manager, click on the Gear icon near the top right of the window and choose the command "Install add-on from file".
The "gear is located under "extensions" and from there you can access the "Add from file". Ubuntu 18.04 Thunderbird 60.2.1.
Great Job with the add on though.
