I have a PlanMaker document that I'm converting from a .csv file, and some of the dollar amounts are in a string format...which PlanMaker can't read as values. Using the Value and Currency functions only results in a #VALUE! error. I've figured out a script to convert those amounts into usable values with a series of formulas, but I need to be able to use Paste Special to put just the values (and not the formulas) in the correct location. All I can find is the Paste method which naturally pastes everything, including the formulas.
FWIW, Paste Special is available in VBA (Selection.PasteSpecial Paste:=xlPasteValuesAndNumberFormats).
I also can't find any way to script a Fill Down (or any Fill operation, actually). I figured out how to get the same result with a For Next loop, but it would certainly be nice to be able to script it like I do in VBA, with Selection.FillDown.
Can't find scripting commands for Paste Special and Fill Down...
americanaustralian
Re: Can't find scripting commands for Paste Special and Fill Down...
You could also do a search and replace for the dollar sign and replace it with nothing.
Then format the cells with the currency format.
americanaustralian
Thanks for the reply, Miguel. Doing as you suggested works manually, but I can't find a search/replace script command. I'm looking in the BasicMaker 2018 manual...maybe that's the wrong place. Any suggestion where I'd find it?
Sorry, but my suggestion was doing it manually without even using BasicMaker. I don't think it can be done in BasicMaker
