Memory issue - lost all images
Questions and answers about Presentations 2018 for Windows
gluemthkid
Post by gluemthkid » Tue Jan 07, 2020 4:16 pm
I was working on a fairly large presentation. 150 slides. Multiple images per slide with transitions.
I was coming to a stopping point when I got an error but it said something to the effect "Presentation has run low on memory and images cannot be saved"
I tried to do a SAVE AS and save it as a different file. but the same error popped up.
I had just saved maybe 20 minutes earlier so I hoped just restarting the app would put me back to my last point.
When I restarted all of my slides and transitions were there including the lasted slides I had added, but ALL OF MY IMAGES were gone.
Is there a size limit or any other system restriction that would cause this?
Please advise.
Re: Memory issue - lost all images
Post by miguel-c » Tue Jan 07, 2020 8:22 pm
If you are using a 32bit version, the memory limit is 2GB. (FreeOffice for Windows is 32bits).
SoftMaker Office has both variants: 32 and 64bits.
gluemthkid
Post by gluemthkid » Tue Jan 07, 2020 8:24 pm
**UPDATE***
Here is the exact message. It happened again. I was re-adding all of my images and got this. When I restart the app ALL of the images are gone again. 4 hours down the drain. This frustrating.
ERROR:
Presentations runs dangerously low on memory.
In order to prevent data loss all pictures have been disabled until you restart the application. We recommend you to save all your documents as soon as possible and run the program again with more memory available.
It is no longer possible to run the slide show.
I am running Windows 10 with 8G of ram.
Post by miguel-c » Tue Jan 07, 2020 8:36 pm
Like I mentioned before, if you are using a 32bit version, the memory limit is 2GB. (FreeOffice for Windows is 32bits).
It's always a good practice not to use many images with high resolution. There are many free applications that you download and batch resize your images to a more bearable size.
gluemthkid
Post by gluemthkid » Tue Jan 07, 2020 8:45 pm
Yup. That was my issue. I was running the 32bit. SMH.
Good suggestion on resizing the images. Do you care to recommend a specific tool to do so.
Post by miguel-c » Tue Jan 07, 2020 8:48 pm
I've used PIXresizer in the past: https://bluefive.pairsite.com/pixresizer.htm
Whitemud
Post by Whitemud » Fri Jan 10, 2020 4:08 am
Same thing happened with me. Have a large media/image rich presentation to give in the morning, and all my pictures are gone. Just got a new PC for Christmas, installed the 32bit and then the 64 - was going to try it before purchasing the software - but still can't regain the images. I've been a Mac user for 18 years, so I'm at a loss to figuring this out in such short notice. Moving to Libre to rebuild my presentation until I can wrap my head around the issue. Super frustrated.
Post by miguel-c » Tue Jan 14, 2020 8:03 pm
OK, but whatever program you use, try to keep the images to a small size, because "big images x many" is a dangerous formula.
Whitemud
Post by Whitemud » Mon Jan 27, 2020 2:31 am
Thanks. Libre Impress saved my presentation for the day, however, it too did the same thing later - which, in a way, I'm thankful for (hate how clunky and crappy Impress is, and this gives me a valid excuse to toss it). SoftMaker Presentation detects the images, but that's as far as it goes. I'll have to rebuild the lecture with lower res pictures for next time. Do embedded videos cause the same problem?
Post by miguel-c » Mon Jan 27, 2020 3:08 pm
Embedding videos might cause problems if they are many and/or large.
Return to “Presentations 2018 for Windows”
