Print Scaling
Questions and answers about Presentations 2018 for Windows
joedarock
Print Scaling
Post by joedarock » Fri Dec 14, 2018 8:42 pm
In Microsoft PowerPoint. the printout on my HP LaserJet printer is exactly the dimensions specified on a screen object's size properties.
In Presentations, the printout is only about 75% of the object's size properties. Further, under the Print dialog in Setup, the scaling parameter seems to have no effect.
Is this a known issue and are there plans to fix it?
Joe
Re: Print Scaling
Post by sven-l » Mon Dec 17, 2018 4:53 pm
I printed a slide from PowerPoint and Presentations that contains an image (printed from the same PC on the same network printer (HP Laserjet 4050). Both programs print the same size of the image. Have you changed the font and menu scaling on the Windows system?
Does the scaling parameter have an effect when you print from PowerPoint from the same PC on the same printer?
joedarock
Re: Print Scaling
Post by joedarock » Mon Dec 17, 2018 7:14 pm
Scaling seems to work on PowerPoint.
FYI, printer is HP MFP1530
Return to “Presentations 2018 for Windows”
