Reference to other workbooks message
joe935
Post by joe935 »
When I open a worksheet i get this message:
This workbook contains references to other workbooks.
Do you want to update these references.
I have searched thru all the pages in the workbook, and corrected all references, but i still get the message.
Is there any way of finding what the message is referring to?
Re: Reference to other workbooks message
Please post the file here or send it to forum(at)softmaker.de (please also include this URL for reference)
joe935
Post by joe935 »
I can not send you the worksheet as it has 4 pages of personal data in it.
This is the same file that had the hiding columns and rows problems (solved by saving the file as XLSX)
Maybe if you do some search and replaces so it becomes less private?
Otherwise, I won't be able to assist you.
PS: only I will access your file if you email it to forum(at)softmaker.de
joe935
Post by joe935 »
I have solved the problem by saving the original XLS as XLSX and all problems are gone.
Thank you very much for the help.
