Quick Access Toolbar
pbmfh
Post by pbmfh »
I would like to see more options (buttons) to choose from to add to the Quick Access Toolbar. In particular, I need the Paste Formats Only and the Paste Values Only buttons added since I use these operations continuously in my work. Thanks!
Re: Quick Access Toolbar
Post by sven-l »
I will refer your suggestion to the product management.
Post by sven-l »
You can enter any button you like through the customize dialog.
