Page Setup
Bobbyboy
Page Setup
Post by Bobbyboy »
How can I set up a page so that it will stay in that format every time I use TextMaker?
Re: Page Setup
I think what you want is to change the default template, called Normal.tmvx, located on
Documents\SoftMaker\Templates 2018\English\Normal.tmvx or Documents\SoftMaker\Templates 2018\English\Normal A4.tmvx. If your language is not English, select another folder.
Bobbyboy
Re: Page Setup
Post by Bobbyboy »
Thank you, all done as you suggested.
How do I do the same for Text - size and font please
Re: Page Setup
If you open the file Normal.tmvx and edit it, all future blank files will have those settings.
For text size and font, right-click the blank document, paragraph style > Normal > Edit > Character.
Bobbyboy
Re: Page Setup
Post by Bobbyboy »
Many thanks for your help, much appreciated.
