Starting some weeks ago, when I open .docx files with tables they have the tables color changed from white to black.
It didn't happen with previous versions and I don't know which version started this behavior.
Why is this happening? Is it a bug?
TIA.
							Tables are turning black
Desktop PC: Windows 10 Pro - 64-bit • Intel Core i7 • 12 GB RAM
Laptop PC: Windows 10 Pro - 64-bit • Intel Core i5 • 6 GB RAM
Re: Tables are turning black
Hi, could you please:
1. Go to the top right corner of Textmaker and then click on: "? | About | Write System Information"
2. Email us the file generated on step 1 to forum (at) softmaker.de and also a file with the black tables
I can send you the sminfo file but I can't send a file with a black table, because I fixed all of them. I will wait a few days to see if the issue happens with a file I created today, so I can send it to you before I fix it.
Files sent!
Hi, I was able to reproduce the issue and forwarded it to the developers. I'll let you know when we have a fix. Thank you!
