Header image problem
Post your questions, bug reports and suggestions here for TextMaker 2018 for Windows.
whatgives?
Post by whatgives? » Tue Jun 11, 2019 10:09 am
Greetings! New user here...
I have come across something i really can't find a workaround for. I've added a header image (jpg, 1500 x 750px) to one of my documents, and when i print it a pixel-wide line appears along the top side of the image. Not sure if this is caused by textmaker, the printer, or something else. Any ideas? Thanks in advance!
Re: Header image problem
Post by miguel-c » Tue Jun 11, 2019 10:34 am
Hi, could you please post the file here. If you don't feel comfortable with it being public, please send it to forum (at) softmaker.de
whatgives?
Post by whatgives? » Mon Aug 05, 2019 8:54 am
A bit late answer, but just wanted to mention that the problem was solved after reediting the file, so the cause had nothing to do with textmaker. Thanks for your feedback!
