Comments muliplied in rtf documents
Questions and answers about TextMaker 2018 for Windows
fnappo
Post by fnappo » Mon Jan 28, 2019 10:27 pm
I'm experiencing a strange behaviour with TextMaker and comments saving in rtf format: when I reopen an rtf file where I put some comments, some of them are duplicated, or even tripled. This does not happen if I highlight a single word or a couple (nor an entire line of text), but (it seems to me) when I select a pretty long phrase, more than two or three lines, especially at the beginning of a long text.
I do not run into the same problem with other formats (.doc for example).
Unfortunately the rtf format is the one I use to share documents with other people.
I'm using OfficeMaker pro, service pack 944.
Is there a bug or am I doing something wrong?
Thank you for your help.
fnappo
Re: Comments muliplied in rtf documents
Post by fnappo » Mon Jan 28, 2019 11:03 pm
A quick example, based on a text file cretaed as a test. Rtf.jpg is the screenshot of an RTF file after I saved it twice. Doc.jpg is the same file saved and reopened more than one time as a .doc format. The more I save the RTF file, the more duplicated comments I find when I reopen it, as you can see in the third picture, rtf2.jpg.
Hope this helps.
Regards.
Post by sven-l » Wed Jan 30, 2019 5:17 pm
Please attach a sample file or send one to forum(at)softmaker.com. Thank you!
fnappo
Post by fnappo » Sun Mar 10, 2019 10:53 am
Sorry, any news about this issue? I installed the latest service pack, but still find multiplied comments inside the text files I save as an rtf format. Did you find something wrong into the sample file I sent you?
Sorry to bother you, but rtf format really matters to me.
Thank you in advance.
robert-l
Post by robert-l » Thu Mar 14, 2019 2:17 pm
Sorry, but I cannot find a mail from you with attachment in forum(at)softmaker.com.
fnappo
Post by fnappo » Sat Mar 16, 2019 8:28 pm
Hi robert-l,
thank you for your reply.
I had a look, I sent it on 30 Jan, with four files attached. Anyway, I've just forwarded it to SoftMaker forum's email address.
Thank you in advance for any help.
