Style Reference No matching text found
jolugaju
Post by jolugaju »
Hello!
I've inserted a Chapter break, then a Footer, then a field with a Page number.
It works!
But when I close the file and open again the footer has this text "Style Reference: No matching text found".
What can I do?
Thanks in advance!
Re: Style Reference No matching text found
Post by sven-l »
In which file format have you saved your file?
jolugaju
Post by jolugaju »
I use only ODT.
I don't know if it's important or not but all my files were converted from WPD (Word Perfect).
This conversion works great in most cases. Sometimes I have to fix a few things nut nothing very important.
Do you need me to send you some of the files with these problems?
Thanks!
Post by sven-l »
Yes, you can send us the file to forum(at)softmaker.com referring to this thread. But I would suggeest to save in docx file format. this should keep the page numbers in the footer.
