Changes made not found, HELP!
Post your questions, bug reports and suggestions here for TextMaker 2018 for Windows.
krondan
Post by krondan » Fri Jun 29, 2018 10:48 pm
Hi;
I've enable the auto-save option to save the document each 3 minutes. The frozen document was closed, because no response from program. When the document was opened again, any of the changes or added text wasn't found. Document show the last saved text on last June 25th. I've noticed that auto-save option shows 8 mins, but anyhow were are the changes previous to the last 8 minutes previous was closed. Any backup or recovery mode/file?
Thank You
Postma
Re: Changes made not found, HELP!
Post by Postma » Tue Jul 03, 2018 10:03 am
I cannot open Textdocument, giving a message that the file is in use adn i can open a copy. I cannot save a document , message disk full
Post by sven-l » Tue Jul 03, 2018 10:08 am
So can you at least open the copy? Please try to save in another folder (with write permissions) on the local hard disc. That should work.
Post by sven-l » Tue Jul 03, 2018 10:09 am
Hi;
Thank You
Please make sure that you have write permissions in the backup folder.
Post by sven-l » Tue Jul 03, 2018 1:27 pm
You wrote via PM that it does not work. What exactly does not work? You cannot open the copy of the file or cannot save in another folder?
Postma
Post by Postma » Thu Jul 05, 2018 12:02 pm
I try to open a folder with write permissions, but if you look at the properties it is still marked read only. The problem with the textdocomenets still persists - i cannot save the changes (I am on windows 10 home edition) Thanks for the promt reply
Post by sven-l » Thu Jul 05, 2018 1:57 pm
What is the exact folder path? Try to copy the files to another folder. Does that work?
