Edit>Find & Replace
Post your questions, bug reports and suggestions here for FlexiPDF 2017.
DE679381
Edit>Find & Replace
Post by DE679381 » Thu Dec 20, 2018 3:44 pm
Hi,
FlexiPDF version 1.11.
The Find & Replace function for large replacement of words (or pages) can terminate abruptly.
I tried to split the work into several batches. Even doing so, I found that there is an out-of-memory issue. Would you please investigate. Thanks.
Re: Edit>Find & Replace
Post by sven-l » Fri Dec 21, 2018 1:06 pm
I will refer that issue to the developers.
Return to “FlexiPDF 2017”
