FlexiPDF deployment
Post your questions, bug reports and suggestions here for FlexiPDF 2017.
rhm
FlexiPDF deployment
Post by rhm » Tue Sep 18, 2018 9:53 am
I have a problem with deploying the .exe file with our deployment tool?
What switches can i use to make a silent install to a remote computer?
/R
Re: FlexiPDF deployment
Post by sven-l » Thu Sep 20, 2018 11:05 am
I asked the developers and will inform you as soon as I have more information.
Post by sven-l » Thu Sep 20, 2018 11:13 am
According to the developers:
There are parameters that allow the installation to be performed
silently without user interaction:
flexipdf2017.exe /SAVEINF="mychoices.inf"
After installation is complete a new file 'mychoices.inf' will be
created in the same folder as the installer. This file records all of
the choices you made during the install such as printer driver
installation, shortcuts etc.
For additional installs you can now run:
flexipdf2017.exe /LOADINF="mychoices.inf" /VERYSILENT /NORESTART
Return to “FlexiPDF 2017”
