[Issue] Ctrl+Shift+B doesn't work for Rebuild
Post your questions, bug reports and suggestions here for FlexiPDF 2017
Temcat
Post by Temcat » Fri Feb 24, 2017 2:13 pm
I cannot invoke the Rebuild command using the Ctrl+Shift+B hotkey. The menu item works, as does Ctrl+Enter. All 3rd party software that can capture keystrokes is disabled, keyboard switching is set to Alt-Shift. This OS is Windows 7 x64.
Artem
Re: [Issue] Ctrl+Shift+B doesn't work for Rebuild
Post by sven-l » Mon Feb 27, 2017 12:16 pm
For me rebuilding Textboxes works properly via CTRL+Shift+B after I selected a couple of text frames with the Text edit tool. Does anyone else encounter this issue?
Temcat
Post by Temcat » Mon Mar 06, 2017 10:14 pm
For what it's worth, I can reproduce this in Infix, too.
Post by sven-l » Thu Mar 09, 2017 8:37 am
I will inform the developers.
Temcat
Post by Temcat » Sat Oct 07, 2017 3:02 am
This is still present in v1.06.
Temcat
Post by Temcat » Sun Dec 31, 2017 2:18 am
Still there in v1.08.
Temcat
Post by Temcat » Fri Jan 05, 2018 10:25 pm
On a desktop PC, Ctrl+Shift+B works as it should. I have no idea what part of configuration can prevent it from working on my laptop because I've excluded the obvious possibilities.
Temcat
Post by Temcat » Fri Jan 05, 2018 10:30 pm
This issue is resolved. For the record, the offending software was TPFanControl, a utility to control CPU fan speed on Thinkpad laptops. I was able to see what was grabbing the hotkey using a free program called Hotkey Explorer.
Return to “FlexiPDF 2017”
