[Suggestion] Open the manuals in the default PDF viewer
Post your questions, bug reports and suggestions here for FlexiPDF 2017.
Temcat
Post by Temcat » Fri Feb 24, 2017 2:01 pm
It would seem logical if the manuals were opened in the default PDF viewer set in the system rather than in FlexiPDF itself — or at least if it were a configurable setting.
Thank you for your product!
Artem
Re: [Suggestion] Open the manuals in the default PDF viewer
Post by sven-l » Mon Feb 27, 2017 11:25 am
I will refer this as a suggestion to the product management. Thank you!
JRM
Post by JRM » Tue May 23, 2017 10:31 pm
I agree with this suggestion. I would like FlexiPDF to use the default PDF viewer configured in the system. I have a very simple PDF viewer installed and I prefer to read PDF files using that viewer rather than having to view them in the editing interface in FlexiPDF.
Return to “FlexiPDF 2017”
