PDF File Size Issue
Post your questions, bug reports and suggestions here for FreeOffice TextMaker 2016 for Linux
Alvin
PDF File Size Issue
Post by Alvin » Mon Jan 23, 2017 7:33 pm
TextMaker has a couple of problems when creating PDF files. When I export a tmd file of size 51 KB using TM for Linux (on Linux Mint 18.1), the resulting PDF file is 528 KB. (The file partially embeds 4 fonts, has a page background color, and uses 128 bit encryption.) But when I export the same tmd file using TM for Windows (on Windows 7 Pro), the resulting PDF file is only 274 KB. That’s nearly half the size of the TM-Linux file.
But take a look at this: When I save the original tmd file as an odt file and then use LibreOffice 5 to export it as PDF (on Linux), the resulting PDF file is a mere 92 KB! That’s less than 18% of the size of the TM-Linux PDF file and barely 34% of the TM-Windows PDF file.
Clearly, the PDF-export feature on TextMaker is running with a serious handicap, especially the Linux version. At the least, TM-Linux should export a file no larger than the Windows version. But even more critical, LibreOffice Writer is blowing TextMaker out of the water with its highly efficient PDF exports. This is a significant competitive advantage of LOW over TM that can contribute to serious consequences down the pike.
The LibreOffice challenge should not be dismissed lightly. TextMaker should have a PDF feature just as efficient as anyone else's.
Re: PDF File Size Issue
Post by sven-l » Wed Jan 25, 2017 4:37 pm
Could you please provide a sample file (TextMaker file) where I can see the effect? Thank you!
Alvin
Post by Alvin » Fri Jun 02, 2017 2:23 am
sven-l:
I sent you a PDF file as requested a long time ago. Please let me know if you did not receive it to send you another one.
Alvin
Post by sven-l » Fri Jun 02, 2017 9:19 am
Seems I haven't received your file. Please send it again referring to this thread. Thank you!
Return to “FreeOffice TextMaker 2016 for Linux”
