Office 2016 on Windows 10
Post here those questions, bug reports and suggestions for SoftMaker FreeOffice 2016 for Windows that do not fit in any of the application-specific subforums.
sprintaco
Post by sprintaco » Wed Jan 03, 2018 2:23 am
Hello
I am using a HP Pro Book laptop with Windows 10. Updated my Office 2016 with ofw 16_768. I got problems at the first use of app.The "Options" window from the "Tools" tab opens with its margins outside of the display. It freezes on and can not be moved. So, I can not perform much of the settings. Same happens with the "Page setup" from "File" tab.
I tried with the last version of Free Office 2016 and the issue still on.
Thank you for help.
Re: Office 2016 on Windows 10
Post by martin-k » Wed Jan 03, 2018 9:32 am
SoftMaker Office centers all dialog boxes on the screen. Check the Windows Control Panel; maybe you have set a much larger virtual screen. Maybe you have set up a second monitor there that is not attached to your computer at all, again resulting in a larger screen area.
sprintaco
Post by sprintaco » Thu Jan 04, 2018 1:06 pm
Hi, Martin.
Appreciate your concern. Problem solved by now. It was caused by a too big fonts size set for dialog boxes.
Thank you.
Constantin
Return to “SoftMaker FreeOffice 2016 for Windows (General)”
