your upgrade script: add_apt_repo.sh
General questions and answers about SoftMaker Office 2016 for Linux. Don't post application-specific questions here, but in the appropriate subforum.
sinistra
Post by sinistra » Thu Feb 01, 2018 6:54 pm
hi, just downloaded your upgrade script and continually receive a permissions denied message on running as su # anywhere I put it.
I placed the script in my $PATH (in this case, /usr/local/sbin/ as there was nothing else in there)
but continue to receive the 'permission denied' error message
./ is no good and $PATH is no good for me
should this script go somewhere else?
oh yes, and thanks for the X64 Deb for Linux Office, a long wait but glad to see it at last
Debian Sid
Linux 4.14.0-3-amd64 #1 SMP Debian 4.14.13-1 (2018-01-14) x86_64 GNU/Linux
KeithG
Re: your upgrade script: add_apt_repo.sh
Post by KeithG » Sat Feb 03, 2018 5:01 am
Hi sinistra
Have you made the script executable? You can do this from the command line by typing:
chmod u+x add_apt_repo.sh
in the same directory where the script is, or add the path to the file before add_apt_repo.sh, ie: chmod u+x /usr/local/sbin/add_apt_repo.sh
After doing the chmod command you can type add_apt_repo.sh and the script will run, provide the file is in your $PATH. If the file is not in your $PATH, then you use the ./add_apt_repo.sh when you are in the same directory as the file.
I believe this script require administrator permissions, so you will need to add "sudo" before the filename: sudo ./add_apt_repo.sh
Hope this helps!
KeithG
Terms:
./ means looking in the current directory
chmod = used to change the permissions of files or directories
chmod u+x = change permission for the owner of the file to executable
sudo = run the command as root (system administrator)
Post by martin-k » Sat Feb 03, 2018 12:19 pm
Yes, you need to make the script executable.
This is only necessary because you downloaded the script. There is no way to transfer such a flag via a download.
The script in the installation archives of the final version is of course executable by default.
Dejan
Post by Dejan » Thu Nov 08, 2018 7:21 pm
Where can I download the script and instalation files for the 64-bit version?
Thanks in advanced!
Post by sven-l » Fri Nov 09, 2018 9:26 am
All downloads for Office 2018 can be found on our website:
https://www.softmaker.com/en/softmaker-office-download
You can find the links for Office 2016 in the e-mail we sent you after the purchase (the e-mail that contains the license key).
Return to “SoftMaker Office 2016 for Linux (General)”
